One of many ways to protect your information is to disable the PDF file “printable” property. In this video, you will learn how to set up such restrictions in your file with our VP online PDF Editor.
Learn the below steps to disable the “printable setting” in your PDF file!
Upload your PDF file by simply dragging your PDF file into our VP online PDF Editor Panel.
Once your file is imported, you can click “file” and select “properties” from the top panel.
Select the “security tab” to view most of the security settings, and click on “Document Security” to open up the setting.
Under the permission setting, you can click on the “printing allowed” drop-down box and select “Not Allow”.
Export your PDF file and you may see that the “printing function” is not disabled!
